Quick one: Where does the rear tow eye attach to the rear sub-frame? Is it under the rear diffuser where there are those two larger bolts going into the subframe?
Cheers,Nick
Cheers,Nick
Yes it is Nick, replace the stainless screw for a high tensile steel one too when you attach it.
Also, if you ever unfortunately end up in the gravel, don’t expect the marshalls to thank you for having to go digging under the car for it!
LOL! There isn’t a MSA approved mini-shovel to clamp on next to it then!?!
Unfortunately not!
…but it’s a good idea…
