MS Seats 5th harness point
Morning Chaps,
I’ve Motorsport seats and 4 point harnesses and have a desire to fit a 5th (anti submarine) point. I don’t want to fix the 5th point to the car, but rather fit it to the seat runners. MSAR don’t have such a fitting so I’m wondering if there’s something out there that I can use?
See here. http://www.exiges.com/bb/viewtopic.php?f=12&t=18662
Sorry but sold the ones I had shortly after as no point putting them back in the garage.
THAT is exactly what i need. Where to find them?
Sorry this is the only place I could find them. Not sure if Dave would have any?
http://www.sector111.com/parts/interior/seats_and_harnesses/anti-submarine_belt_bar.cfm
Bought some from the factory. Several years ago.
Are you sure you want just the 5 point. Quite uncomfortable. And could be a serious threat to the manhood in the event of an accident.
6 point is really what you need.
Clive…is so true those harness you have it in the orange is a nut cracker when break hard!!
6 point sounds the preferred way then! The same question still stands, how do I achieve this? I have the original scroth/safety devices harnesses and buckle, and want to anchor the other points without drilling the car.
Thanks,
Kurt
Not aware of a solution for 6 point that doesn’t involve drilling. If you want to go that route would suggest looking at the neater solutions. Take a look at Sector 111 again. On the 5 point being uncomfortable then I agree as that’s why I moved to 6 in mine.
The two straps of the 6 point still have to go down the same hole in the seat.
So … What’s different for the fixing to the seat ?
I have 6 point with the seat fixing for 5 point
I’ve just whipped the pax seat out and I concur, the harness (5 or 6 point) would need to fit through the same slot. I can only assume that the 6 point is wider above the seat and spreads the load if ones tezzers connect with the ASM strap?
I have seen the 5th and 6th points fitted to the rear seat mounting bolts to the chassis, I presume they must have used longer bolts and they went between the seat rails and the floor, I think there might even have been a flat metal plate between the 2 bolts and they bolted to there, my memory is sadly a little hazzy but it was definitely the rear seat mount bolts used.
