Motorsport engine cover
Anyone done a Msport engine cover with a stock roof? Any tips on what do do about the hinge?
If its an S1, I re used the hinge and plate and attached to the MS cover and also re used the D pin at bottom of perspex so I could use the pull cord for security. Also added a clip on each side to keep flex and prevent sheering in high winds. I cant give any fitting tips as I got the boys at Plans motorsport to fit and paint - I know my DIY limits.
M
most people just remove the hinge to allow more airflow
M
You would’nt have any pics, would you?
Sorry none of the hinge area at the moment, will try to grab some in next few days if that helps…quick release clips all round would have been an option but was concerned about some one getting access to the boot ehmmm
I also extended the front airscoop to improve airflow…
Thanks, John
