I had a M/S Ecu fitted about a year ago and it has worked well with no problem.
Just had a service done at Lakeside Engineering and on the way home noticed it had reverted to it’s old 6200rpm cam change. Has this happened to anyone else. Could anything done during a service have caused the ECU to go back to it’s old ways ?
As far as I am aware this can only happen if the ECU was reflashed, or if it was replaced. Reflashing at a service would be unusual unless you had reported a fault for which Lotus had released an updated map, such as the stalling on coasting problem that the early cars had.
That’s what I thought so was surprised about the cam Change. It was pi$$ing down this morning so I will check again more carefully when weather settles down.
Whilst still holding the reset button turn the key in the ignition to the second position (just before the engine turns)
The Stack will then wind both needles back to below the zero position, and the LCD will show the software revision number. Once it’s gone through the motions your speedo should then read true!
[/color]
Thanks. You didn’t mention that it only works if you have on eye shut, are wearing purople trousers and it’s an even odd day of the month. I heard on the “S” it only works on even days of the month.
