I maybe able to help you Andy. I think B&C returned the original MOMO one when they fitted a Lotus one to my removable wheel. It’s at the back of the garage so I wouldn’t be able to check until the weekend - feel free to prompt me on Friday.
ps. Simon while I’m going back there I could put the Cat back if you’ve finished with it?
When I got back last night I had a look at mine and the snap off is exactly the same but there is a red flat disc and a spacer between the snap off and the wheel.
There are 2 rivets on it to correspond with the 2 on the steering column side of the snap off kit! The spacer creates a bit more room to get the wires in etc.
If you get stuck and cant get a Lotus horn push, have a look, Im sure you’ll be able to make one.
Here is a copy of a mail about the snap off kit - Michael is your man at [email protected] - he was real helpfull.
Hi Andrew
There are several versions of the Snap Off,
Special order, non painted aluminium, no lock, used extensively in Sweden
for racing. It is made by CNC so the finish on the aluminium is great. It is
however, more expensive than the others.
Standard Snap Off, aluminium painted black, with block lock which is
removable. It might be possible to supply this version unpainted, but it
would be need to be treated or sandblasted to give it a better finish than
it appears from the mould.
Snap Off 2000, painted black, with integral lock which automatically
locks on and requires the key to be removed.
1 and 2 are only available by mail order, 3 is available in a number of
stores and by mail order.
