Moisture in headlamp cover
Hi, i notice that my nearside headlamp cover has moisture in it. Can’t see any problems with the seal around it. Anyone else had this problem? Is there an easy fix or does it mean removing the cover and fitting a new one?
All wisdom welcome.
Warren
It’s an easy fix to remove and re-seal. You can buy the new sealant from Elise parts.
Does the original usually come off in one bit?
or you could leave all the visible bits intact and go in through the wheelarch liner.
and as this is where and dirt or moisture is getting in, maybe try and seal the clam edges better?
