I seem to have an issue with the Amps to power my TFT, will know more later but I think it’s down to the Odyssey 6kg battery only cranking 220, I need 300
Well if you are going to have to put the big battery back in you may as well fit the sub-woofer and neon’s as well
and wots wrong wid fitting a sub in the exige lol. i did it and love it lol
Nitro so what you listening to dude…?
Ok so forget my last we’re up and running TFT, driver and camera all AOK, wrong wire bit of rush last night…Don’t cut the purple one
Anyway these two are for the Shifti, Steve still going with the ciggy lighter and a single pole switch on the live…I found one that looks like it came off an RAF Tornado…BOMBS AWAY
I’m going to have laser cut a bracket that will fit and rivot to this part of the dash. It’ll fold up at 90 degrees holding the TFT then back at 45 degrees secured neatly to the dash holding the driver board. Here it shouldn’t get in the way.
RIP Gomez 1993-2009 We’ll miss you.
Sorry to hear about Gomez mate, our cat Rosie has more than a striking resemblence…
OMG Pete it looks just like him!
Went blind and couldn’t cope. Tumor on his foot and bleeding from both ends…total total wounder. Put down yesterday.
All done (kind of) waiting for the MSD tac pick up for the Shifti but done nevertheless. The cam is fitted in front of the plate holder so should be ok with the heat, we’ll see either way can be easily replaced or made to work with a bit of HS. The cam connects to a separate video and power loom in the boot. That runs through the engine bay, under the airbox along with the cable for the Shifti then through the bulkhead. N goes straight to lighter socket, L to bombs away switch. Lighter socket L spliced with second wire to bombs away switch (opposite side). The TFT/LCD metal work I made, it is riveted behind the central vents and screwed through the dash, it�s solid. The screen has 2 inputs AV1 & 2, 1 is for the rear view cam and 2 can be from hand held (fixed) video cam playback or perhaps a video datalogger. Screen L goes to switch, cam side and N to same earth as Shifti under the dash.
Cough, splutter!!!
Jonny, please say that is some kind of April 1st comedy photoshop!?!?!?!
Just waiting to see it, once he’s stuck the fake diamonds around the outside!
I’m impressed you’ve found space to cram all that wiring into the centre consoul. Should be like having heated seats with all the current flowing through there now
I hope you’ve made a wiring diagram for all that if it goes Pete Tong!
should have gone to specsavers,hope health and safety dont see that
You’d never guess mate
Lol I love it, it’s ace The wiring is a piece of piss nothing’s not as it should be. The Shifti is quite straight forward, I only added the telly…I’ve no idea where I’m gonna put the dish, got any ideas Ben
You’ll need some Vaseline
PMSL at Ben - but bloody hell,… you been watching too much “The fast and the furious” JF ?
You’ll need some Vaseline [/quote]
I’ll ask Sean … anyhoo it’s not finished
:whistle:
Jonny - just ditch it, mate!
