Missfire
Long time since I posted,that’s life.Have a problem I went to jump start car under front hatch and like a cunute on wrong terminals just touched!.Started car noticed fuel pump seemed to run a little longer than usual.Took car out felt normal except cam change point (4k rpm) was more pronounced normally you can hear change point rather than feel it.Then at 5k rpm in any gear Max rpm light comes on and at 6k rpm engine cuts as if you have reached 8 k rpm.Car is a Toyota engine fitted 8 years ago with a Bemani MP 90 supercharger kit.Car pulls normal at all revs up until it hits 6 k rpm .Thanks for any suggestions
Update found blown fuse 5 amp.Back to normal…
Good to know for future reference. Seems a little like the cold start rev limiter had kicked in, I wonder if its related.
Glad you got it sorted!
