Mintex 1144 Brake Pads
I have brought a pair of Mintex 1144 Brake Pads for Road use on a standard Exige S1. They have come with a rubber backing to reduce brake squeal. Has anyone fitted these pads and would any one recomend either fitting or not fitting these eadhesive backs for Road use? :confused:
I’d fit them. Will also will reduce “pad rattle” as they wear.
I believe the rubber pads will stop (or reduce) low speed brake Squealing.
1144’s are fine, but create lots of dust. Make sure you fit the backing strips.
thanks all
