Evening.
I think my MFRU is playing up. I have bought a spare ( cheap ) and wanting to changing it. I have removed the undertray that obscures the exhaust but cannot still reach the thing.
Can I just remove the rear wheel arch liner and do it that way?
Is it near the ECU? If so access might be obscured a bit by the airbox but you should be able to get a good hand in if you take the airbox out via the wheel arch liner
I couldn’t see it buddy. I eyeballed it everywhere
Hmmm. I think mine must have fallen off the hook.
I guess Ill have to take off the snorkel pipe , remove the ecu and have a look. I just could not see it tonight .
It’s a bloody pain of an area to access with an SC’d car tbh.
I had to find an earth point for my CC pump in that region and it was lots of fumbling about blind. Best of luck
Thanks.
At least I have a replacement to know whay I am looking for now.
Its a black piece of plastic , in a black hole , in a really inaccessible part of the car.
Brilliant.
You say you removed the exhaust undertray (Diffuser?), try the other one - you’ll need the car on stands and you should be able to get a hand up from the bottom, I can just about reach my ECU from the floor.
Yep, plan b is to go from that side.
I found it!
Air snorkel off
ECU Off
Hand between my cable throttle and firewall. It’s there!
I unclipped it but I haven’t got the dexterity to unclip the clips and hold it at the same time.
This is a job that would take about 18 seconds with a lift.
