Due to set off for Classic le Mans 1hr ago. Car won’t start.
Turning over beautifully. No spark at plugs.
No smell of petrol as might be expected after repeated attempts to fire her up.
Any suggestions?
Yours in haste . . .etc
Any suggestions?
Is the fuel pump priming when you turn the ign on?
Check the fuses/relays between the seats behind the inspection hatch.possibly a blown one.
If they are all ok it could be that the battery is in a poor condition, it is quite common that it will crank over but wont start as the power is not enough to keep it running. Try using jump leads from another car to see if this boost the power enough to start it. If it does get a new battery asap.
Hope this helps a bit.
Good luck.
Steve.
