Mad couple of weeks
Bloody hell had a pretty mental couple of weeks. As a few of you knew I had been asked to enter a competition called GT Battle on the 25th June (www.gtbattle.com). There were three classes of cars FWD, RWD and 4WD. They had made a 1.5 ish mile circuit on the infield of Rockingham and the top 12 overall qualified for the finals.
The weather was really bad, very heavy rain, but I gave it my best shot and at half way I was 2nd overall!!! I couldn’t believe it. There were some mental powerful cars there and i thought the 4x4’s with the weather would rule, but there I was behind a 550BHP Escort Cossie with a professional driver at the wheel. Unfortunatly it started to dry out and the long straight to the 1st corner was helping out the poweful boys. In the end I qualified 5th over all and 1st out of all the RWD’s which included 4 modified 911 GT3 RS’s. I was well chuffed.
Unfortunatly for the final they changed the track to include two of the straights of the main oval and the banked bend and my little 200BHP couldn’t compete with me ending up 12th overall on a bone dry track.
One of the monster power Skylines was actually clocked at 198MPH down the back straight. Every car in the final had at least twice the power of me and most had about three times the power and twice the amount of wheels doing the driving. Was an all round top day though and the car ran perfectly!!!
The following weekend was an RS track day at Croft. Again the car ran faultlessly and showed up ALL the big power boys. There was a 580BHP RS200EVO there doing charity passanger laps and two of the people that went out with him, later came out with me and both said I was faster. I really do love that track now, you can attack it so bloody hard, I was going round there like a mad man by the end of the day. Big thanks to the Plans boys for revising the setup on my car it handles SOOOOOOOOOOOOOOOOOOOOOOO well now, i have supreme confidence in it, it’s awesome!!!
Then last weekend there was another RS track day at Castle Combe. I thought I might struggle here as Combe is very much a power circuit, but I found I could carry that much more corner speed that I was just as fast down the straights.
Unfortunatly the car did not run faultlessly.
I lost the clutch after the 2nd lap on my first session. It wasnt a problem on track as I have got into not using the clutch at all now with the Quaife box, so I finished the session with the clutch pedal on the floor and my heel and toeing technique much improved. (thank god for dog boxes!!!). After the session I found that the splayed tip on the end of the 90 degree hard pipe on the end of the braided hose that enters the slave cylinder had broke off. The fitting was still tight in the slave cylinder, with just the tip of the pipe itself having broke off. Anyway a quick blast with a brake pipe flaring tool saw a new flair on the end of the hard pipe and normal clutching action was resumed!!
Then on the 2nd session about half way through while braking for Quarry I heard a bit of a knock at the back. I had just thought something had bounced up and hit the floor pan or something and the car carried on perfectly so I just kept my foot in. Another half a dozen laps and the seeing off of a slick shod 380BHP scooby saw the end of the session. On my drive back to the paddock, I pulled up to let the guy in front reverse into his parking space. I then selected first to pull away and the engine just died. Thinking I had just stalled, I turned the key, only to hear that high speed, no compression whirring.
Yep sure enough, the clonk I had heard was infact my bottom pulley falling off and the rest of the laps I guess the cam belt just worked its way off until off it came. Luckly it hapened at vertually idle speed, so fingers crossed it will just be bent valves. At worst I guess I may have broke a few guides.
Anyway I am working in LA this week and next so a mate of mine will be ripping the head off if he has time to survey the damage.
So after a dozen or so full hammer track days with zero problems, I had a bit of a mare at Combe!!
Moral of the storey is to check that bottom pulley bolt as part of your pre track day inspection I guess. I had never taken mine off, so never really thought about it.
Will be all repaired and ready for a two day double header at Donno in August!!!
Ho Hum!!!
Sean…
Thanks Sean for the excellent write up, & well done Sorry to hear of your woes at Combe - fingers crossed it’s sorted for your return from LA - hope it’s not a porn movie you’re starring in
But how can you have heard the noise on the track if it was the pulley?
Unless I understood wrong, but maybe just the screw, and when reversing then the pulley came off and it all died.
Oh well, ta least no big damage was done.
I’m sure some dimwit will use this as statistic to add yet one more failure to the K
Excellent write-up !
blagged a ride with Sean at Croft - toppermost hoot!
Awesome brakes
Superbe M3/Skyline mawling action
Just a few more horses required
My elise belt snapped at idle and it did a lot of valves and a few less guides - cant remember exactly - trying to forget that and the associated bill!!!
The noise I heard I am assuming was the pulley comming off at 8,000rpm and hitting the undertray before exiting through the wheel well. Someone in the crowd told me they saw something fly off my car and it was recovereed by a marshall. So off I went walking down to quarry and the marshall said he saw the pulley drop off and it actually over took me as I braked for the corner.
I guess that is the definition of a bad day, when the only thing that overtakes you is your bottom pulley!!!
Sean…
Sean… I’m a little confused???
How could you do any more laps at all with the pully off? Or just the alternator pully? All sounds a bit odd and very much bad luck fella! Hope it’s OK!
Yeah it was the alternator pulley that fell off. But that obviously holds the cam belt in place, so for the remainder of the session following the pulley falling off, the cam belt must have been working its way off the sprockets.
Sean…
Hmmm, strange.
Errrrrrrrrr
So… the BOTTOM alternator pulley came off and the cambelt stayed on? That’s damn lucky to be honest as there’d be nothing holding the crankpulley on at all. It should have just fallen off.
Inertia?
Errrrrrrrrr
Yes.
It was obviously an inertia thing as it was fine until I stopped. Mind you the cam belt has acted like a saw blade and completly chopped through the plastic cam belt cover, so I guess that helped hold it on for as long as it could.
Sean…
Sean
Crap… sorry to hear about your troubles, but sounds like a small problem for a man of your calibre… very excellent writeup tho - very interesting reading, excellent result at the shoot-out thingy at Rockingham. Why’d they make the course so straight in favour of the power barges tho ?
hope you get your woes fixed… but i know you will.
Cheers Roxx,
Yeah the car will be back on the road pretty soon after I get back. It will be top of my list of things to do.
Yeah it was annoying when the finals were run on a much larger circuit with two massive straights.
In the qualifying it was very wet and it was a great leveler, but even in the qualifying as it began to dry people were putting in faster and faster laps all the time. I did my fsatest run on my last lap, then the guys that finished 2nd, 3rd and 4th all ran after me and went quicker. But there was not enough time for me to run again.
The cars in order of finishing the qualifying were:
  1. Escort Cosworth - 550+BHP
  2. Lancer EVO 8 - 650BHP
  3. Nissan Skyline - 690BHP
  4. Nissan Skyline - 650BHP
  5. Lotus Exige - 200BHP metro engine
  6. Porsche 911 GT3 RS - 420BHP
  7. Lancer EVO 6 - 600BHP
  8. Porsche 911 GT3 RS - 420BHP
  9. Lancer EVO 5 - 500BHP
    10.Porsche GT3 RS - 420BHP
    11.Nissan Skyline - 800BHP
    12.Escort Cosworth - 450BHP
I know some people may scoff at the power levels of some of the cars. But all of the cars above are quite well known and I have seen the dyno graphs for them personally.
It just goes to show that power is nothing without control!!!
It was certainly an interesting day.
Sean…
Just as a matter of interest, the Escort which finished first, is owned & driven by Gareth Lloyd - one of the regular Tracksport instructors who was at Croft with us. Gareth is a very unassuming true gentleman, he is also a “Ring” instructor, & has succesfully competed in the “24 Hr Race” there on numerous occasions.
Yeah Garteh is a great guy and has been a good friend of mine for a fair few years. As Pesky says he has competed in numerous ring 24 hour races. He took his F40 to the ring a few years ago, unfortunatly i wsn’t there, but a friend of mine went round with him in it, and to this day says it was the most aamzeing thing he has EVER done.
Sean…
Sean…
fukkk mee… serious clydesdale horses there me old mucker.
jeeeesus
jeeeesus
I know it’s childish but I don’t think I could have resitied making a big LooooHuser “L” sign at hime
i think the 800bhp skybus is owned and driven by Nicolas Kiesa an ex Minardi F1 driver
some videos of his skyline can be found here exvitermini
