LSS question?
Has anyone got a set of LSS lying around who could measure something for me.
I want to know the length of the front and rear dampers from the centre of the bush at each mounting point?
Hi Mark,
got a set in the garage.
will have a look tomorrow - or give me a call and you pop over and measure them youself if you’d rather.
If you have no luck I can measure mine on Tuesday.
Thanks Con, are you around tomorrow, if so I’ll give you a call and pop over.
Should be around most of the day Mark
Hi Mark,
Fronts are 355mm
Rears are 380mm.
HTH
Thanks.
