i allways think that the car is so high on it’s feetother sportscars are much lowerwhat’s the reason ?is it possible to get the car closer to the ground or wouldn’t this change anything
You can bring down the ride height more, but you start getting issues with the wheels rubbing on the wheel arches and splitting the clam (You could file away at the lip inside the wheel arch if you wanted, and fit stiffer springs).A more significant problem is that as you reduce ride height you will increase the bump steer (unless you want to start playing around with the steering rack). Mine is lowered to 95-100 and it is not nice at anything but the smoothest roads. On circuit it is fine.Personally I would not do it unless it is a commited track car.Cheers
