Dont know if it is normal but mine does it as well. It is flames exploding out of the exhaust . Take it you have a cat pipe and sports exhaust as mine doesnt do it with the cat in.
Only time i have had that is when i have had to out of desperation fill up with bad fuel (low octane), it’s not the usual pop and bang, more like a platic bag being popped ? Try filling up with some good quality fuel.
At the risk of being laughed at i would go so far as suggesting that if it continues and never did it before, it could be the lamda sensor.
Sneaks off to dissapear into crowd inconspicuosly -
I only use Optimax as well and it doesnt do it with the cat in - so I assumed it was due to having a straight through exhaust and cat pipe. I have the Eliseparts back box which is about as straight through as you can get!
OK�…what is a Lamda sensor and why are you sheepish to mention it?
Carttman
the Lambda sensor measures the oxygen level in the exhaust to make sure the mixture is optimum for the catalyst (but not optimum performance). If you have a cat bypass or computer that ignores the lambda probe it is irrelevant.
