Anyone fitted one of these?
Got any fitted photos?
Just trying to get my head around the front edge of it and how it will fit against the footwell divider?
Thanks - couldn’t work out why or how the two original parts - transmission tunnel & gear lever cowling - were replaced. It looks like this only replaces the tunnel then but seems strange why it has part of the cowling also?
It doesn’t. Its exact;y the same shape as the original tunnel.
Dan
Not on mine it isn’t?
Mine looks like this:
Steve
It replaces the bit underneath the handbrake, hence Dan’s comment.
Rob - I’l have to take the gear lever cowling off & check - i just don’t recognise the front edge of the replacement piece!
Tried to find a picture on line but failed…
Doh! Guess we should change the description a little. They are a direct replacement for an Elise, a bit of modding/trimming is required to fit an Exige. The bump at the end is the rear of the cabin
If anyone has part 12 lying around I could do with one of them.
Not in carbon, just plastic.
p.s. Sorry Steve, forgot the Exige was different at the back end.
Dan
OK - I was being dense - I thought that the bump at the end went to the front! It now makes sense to me…
I have got a full Carbon Fibre interior. Admitedly mostly made by myself but when i moulded up all the interior removeal parts(less the dashboard complete) i recollect no troubles with the handbrake console you refer too. Only thing you have too do is cut the section out fot the handbrake and then drill a couple of holes to put the fasteners in too hold it too the gear lever surround and the rear centre spine. No great shakes really. I have pictures somewhere on one of the old hard drives. I’ll fish em out and send them to you.
