I’ll put the same answer that I put on SELOC, or words to that effect
It’s the same as an OEM roof but it will come supplied non-lined, you’ll need to get it trimmed yourself. There are three plastic trim panels that I think Jon also sells separate (or you can use the OEM ones), but they’re optional.
Yep the plastic trim panels are about £100 if they are sold separate and then trimming costs on top - but with your skillset I’m sure you could DIY trim it!
