First of all, the only reason I am selling it is because I decide to go for a conversion. There is nothing wrong with any of the parts of this system. I guarantee it is in a perfect working order, just like new (I could say even better!).
Now, about the system; what it includes (new prices):
QED Dry sump kit (Dry Sump, Oil Pump, Oil tank) (~�1930)
Goodridge Kevlar or S/S Braided (most) hoses and proper (AN) fittings (most crimped) (about �600) + a few Arequip rubber hoses (where temperature is not an issue).
Mocal Remote oil filter (with threads for oil pressure switch and oil pressure gauge) (~�30)
QED windage plate (�55)
Mocal Oil Cooler (�60)
Heat shield fabricated especially for the Elise chassis (�10)
Weld on AN adaptors to the tank (no push in ones) (�60)
All proper mounts for everything
I will include a quick release fitting (�250 alone) for the oil pressure gauge and the gauge (�50 inc fittings and hose)
Oil catch tank + breather (�60)
Fabricated aluminium tube in order to avoid tight angles to the flexible hoses (in a particular point) (�10)
Modified original oil pump (so you can just replace and keep yours) (~�100)
Pulleys and two belts (�10 each)
Finally, the rather most important bit (in some cases of course), the J-B Weld epoxy adhesive (�10)
A few of you know that I have experienced a few issues with this system, due to a leak. In a few castings of the Rover block, there is a square cut (which does not do anything ). Using the J-B weld you will have to fill this cut so you wont have the same problem. To be honest, I�ve tried to do this today, but unfortunately I have to remove the whole engine (solid manifold you see�). I am sure you can feel my frustration! So, I�ve decided to give it up and sell everything (there is already a friend who will buy the VVC engine and the Quaife gearbox ). Believe me, if I wasn�t 100% sure that this system is working in a perfect way, I would never sell it.
Everything is ready to be installed (as soon as I remove them from my car of course!).
If you would like to build this system, the min you would spend is �3200 (plus many hours for the circuit design, hoses and fittings order and fabrication). I am looking for �1500 (or �1350 without the quick release fitting and the pressure gauge).
Pictures to follow :
