The original 2 pots have 2/3mm overhang on the brake pads in regards of the disc. Not something I like.
Did anyone fit the Lotus AP calipers on the s1 alu uprights? I have 308 mm discs / 16" wheel etc.
Did it fit? No adjustments needed?
The pistons are not larger then the 2 pots so other brake master cylinder should not be needed?
This means also the balance should not be changing to much.
( AP 290 rear, going to be turnend down to 282mm, with Pagid 14 and 308mm front with pagid 42 , altough they come delivered with Ferodo 2500, maybe I use these until they are worn instead of throwing money away )
The Lotus BBK kit fit perfectly on the Lotus Elise/Exige S1 alu hubs. No adapters or anything needed, direct bolt on. I only had to create custom spacers as the spacers I offered earlier are to high.
Standard Brake Master Cylinder, no extra pedal travel. Will take some photo’s today
