My Exige handbook states I have an interior lamp for night time / when the door opens etc. Where is it? I can’t locate it!!
Does the area around the fan speed dials / cold/hot temp setting illuminate when the lights are on. Mine is totally dark in that area which is a bit frustrating!
The interior light is on the aluminium shelf that runs across above your knees, towards the centre of the car, up above the cigarette lighter socket… It has a standard three way switch… It is b@gg@r all use when map reading and driving though !!
There is no lighting around the heater controls - you need to memorise them in some way
Strange but true - there are two yello LED’s above the heater controls on my aircon version ( I assume they are there to throw light on to the controls … ) - but I know they do not light up …
Temp sender is in modified sump plug and pressure sender will be ala De Edwards installation - which means an extension from the existing pressure switch with -3 braided hose to a “T” piece where both pressure sensors go.
I mounted an oil temp gauge on top of the gearlever surround instead of the cigarette lighter in a pod.Looks neat and there is a ready made power source with lighting at night.Sender is in the sump-plug.
