I set about fitting mine today, more of a faff than difficult but I’ve come up against a bit of a problem. I cant get any of the forward selected gears 1-3-5 and I think the cable bracket is the problem, or lack of said bracket. I’d seen the kit on the website and it clearly shows a cnc’d alu bracket that the 2 cables are clipped to. My kit didnt come with one and had an additional alu wedge instead. I made the assumption that this was so the standard bracket could be used. Seems I may be wrong and that the new bracket would place the cables a bit further back than the standard one does, allowing the movement needed to get the forward gears.
If anyone has fitted one, especially if they got it from Brooke-Kensington could they confirm if they had the new bracket or not.
I’m going to leave the damn car in bits and drink beer instead.
Most of the guys that track their cars with te lesta setup have all replaced it or modified it so that it would work properly…None of these guys left it in the short throw location…
