Basically they should be replaced under warranty. Lotus have admitted there is a problem with all LED lights marked as part no. Axxxxxxxx the “A” is the important bit.
They have a revised version which is part no. Bxxxxxxxx. This is the reliable version which does not require the jump harnesses to suppress radio interference.
Most dealers don;t seem to know any of this but tell them to call Lotus tech. and they will confirm.
The big problem is the supply of the “B” part which I think is still pretty limited.
If all else fails there are some on eBay at the moment.
It was pre registered by JCT 600 on 22/05/07 and I purchased it on 22/06/07
I gather the warranty is transfered on so I should be OK ?
I’ll get it booked in next week - only issue is availablity of replacement parts - after searcing the forums all morning is there still a shortage of the type B replacements ?
Anybody had recent experience ?
Thanks for all the posts - didn’t fancy a few hundred quid for some bulbs !!!
Unless you are changing them for “B”'s don;t even think about it. Some guy on eBay has a set which I verified as B’s at the moment. I suspect they won’t be overly cheap though by the time bidding finishes.
