LED Light question
I’ve just installed my replacement outer LED’s in place of the faulty originals.
My good lady wife did all the pedal & button pressing bit while I checked that the new lights were working (they are), & noticed that the inner pair of original LED fog lights only illuminate 50%, this being the ‘inner crescent’ in both cases IYSWIM. Is this correct, or are these faulty also
It does seem a coincidence that the same ‘part lit’ pattern is visible on both though Shouldn’t all of them work
Tim.
I believe that’s correct. Mine are the same. They light up in full circles for everything but the fog lamps.
The other way is to convert the inner ones to the outer version. So, when you hit the lights, it’d all light up nicely like a Skyline, Corvette, Ferrari in date comparison.
Tim the inners ar only fog no side or brake and as such only illuminat half, if you look closely you will se there are only led’s in half of it. However if you get the us inners then they light up full ring on side and then either full fog or brake, thats what ive done.
Gav
Thanks for the replies folks
Looks like mine now work as intended, so I’ll leave as is.
Cheers.
