My S2 has developed leaks above both doors towards the rear. Roof lining above the window is soaking. I read somewhere a while ago that is due to a seal gone round the S/C intake vent on the roof, mositure seeping in & gravity finding it way between the roof shell & the lining to the edges of the roof where it meets the rear clam.
Anyone any ideas? Tried SELOC a while ago & not a sausage. Their TECHWIKI has no info either.
It’s probably of little help but my old Elise had a hardtop fitted to it a few months after I’d taken delivery of the car. Apparently they had to fiddle with the windows (dropping them down I think) to get it to fit properly.
Sticking my neck out, is it possible that your windows need re-aligning? Do the windows wobble in the door frame when the door is open? Can you wobble them with you hand?
Might be a job for a dealer if you have one local to you.
[quote=Echo66]My S2 has developed leaks above both doors towards the rear. Roof lining above the window is soaking. I read somewhere a while ago that is due to a seal gone round the S/C intake vent on the roof, mositure seeping in & gravity finding it way between the roof shell & the lining to the edges of the roof where it meets the rear clam.
Sounds like exactly what you said, my old exige S used to do it. I would remove the roof and use a smallish paint brush taped on the end of a long tube to smear silicone down the inside edges from the rear opening.
i agree with boothy, i did this and silconed greased all the seals and it worked perfectly, but the windows is also a very good point they do need doing also,
Don’t want to worry you but my 1st s2 exige s did this and it turned out to be a cracked roof, you obviously couldn’t see it from the outside but nonetheless it was cracked and leaked like Neil from the Young Ones shoe with a hole in it.
Good bit of KY Jelly will do the trick on the seals.Lotus tells me to do it all the time i wash it. Does not look right buying it from the shops and saying its for my car.
Finally got the chance to have the roof off & try to sort this. Car has been stood for 3 weeks & the passenger floor mat is soaked (iced solid truth be told & i have ice on inside of all glass). Roof is off & i’m having a good old go with the sealant.
One thing i have noticed after reading a SELOC thread or two is after taking the mesh panel & surround off the short roof scoop there is a blanking plate behind completely sealing the roof scoop behind the mesh. Huh?
