anybody had a problem with fuel leaking from petrol cap on a hot day? not good for the paintwork! also had to replace the rubber gaiters on front tie rod ends?? very expensive at hr owen i`ve heard lakeside engineering are good…?
Lakeside comments here: http://www.exiges.com/ubb/NonCGI/Forum1/HTML/000874.html
thanks, did you end up going to lakeside to get engine mount fixed?
quote:Originally posted by misterpink:thanks, did you end up going to lakeside to get engine mount fixed?No, if you read down the topic it turned out to be a drive shaft bearing. It’s a long story but B&C took �400 off me and didn’t return it for weeks. They did say sorry and offer a cheap service though (although Lakeside would probably still be cheaper!).
