Did not get a chance to sort mine out last week, but have exactly the same symptoms,i assume it to be driveshaft sealsas the speedo drive plug seems clear. will report back tomorrow hopefully. Most likely cause on the board seems to be speedo sender that is not used on the exige, but do a search on gearbox leaks should help.More than likely some seapage or the driveshaft seals.
TBH, I doubt it’s the speedo sender, that’s much higher up and wouldn’t be too near the long shaft…
Almost 99% sure it’s the gearbox seal, very cheap part and not too difficult a job at all, just pop the driveshaft out, pull the old seal out and rubber mallet in a new one
But can you tell if it’s gearbox oil (quite thick and has a slightly sweet smell to it, that’s if it’s MTF94) or engine oil (probably black as sin and not such a sweet smell)… Gearbox oil and it’ll be the driveshaft seal…
Or has a CV boot split? Is it thick grease rather than oil???
I had my mechanic over to look at the leak this weekend - he thinks it is the inner CV leaking, not the driveshaft seal. It’s my understanding that the CV is packed with grease - does any trans fluid flow into the CV?
Excuse my mechanical newbie questions (I’m good with the basic maint. stuff)…
No, the CV joint is sealed from the gearbox and as you say is filled with grease and not oil. If your leak is oil and not grease then it deffo sounds like the driveshaft seal. I guess the oil may have soaked the CV and may look like it is coming from there.
I think it can only be gearbox fluid and that the seal has gone. There’s nowhere in that area that could leak engine oil onto the CV joint as far as my memory serves. Plus if you smell the fluid, gearbox oil has a sweeter smell than engine oil. Pull your dipstick out and sniff that if you can’t tell the difference.
Yes - the CV book is soaked with fluid. I can’t see any motor oil leaking down anywhere so I assume it is gearbox oil.
Please note that the grease can look like fluid after a CV boot has let go - as already stated you need to compare with engine and g/box fluids and if colour/smell are different then assume its grease.
