Please, what I have to insert in the two taps in the picture?
I close them?
Thanks
Uploaded with ImageShack.us
I close them?
Thanks
Nobody can answer?
you might have more joy with getting an answer during this evening, not everyone can read the forum during the day
Thanks, maybe I understand
The large pipe must be closed, the small tube is connected to the fuel pressure regulator.
I hope I’m right…
Have you taken pipes off???
I can check mine tomorrow but of the top of my head, one should go to the fuel pressure regulator, one to the map sensor and the other is blanked off.
Here you go
Yes, i think it’s right
You do like fanta, I would consider a better filter than the hurricane you have fitted as they have been known to sap power.
I begin with Hurricane, because it is closed filter air and compresses well, does not take hot air from the engine and does not create vortices.
Then I think of new solutions.
I think that with JRSC the filter should be closed. At first Exige S2 I had good results with closed filter;-)
