K series Distributer loose
Just preparing for Goodwood and found the distributer a bit loose .It moves a couple of mm in its mounting.
I note only 2 bolts hold it although there are 4 holes.
Is this correct or do I need to tighten things??
Hmmm, you confused me there.
The VHPD doesn’t have a distributor, but a dual coil pack.
As far as I remember it is indeed held by two bolts, but should not feel loose at all.
Maybe a picture could clarify your setup?
Sorry to confuse Uldis …See if this helps
Thanks
[image]http://i27.photobucket.com/albums/c165/cliveagyoung/lotussparks.jpg[/image]
That’s the dual coil pack, and the bolts shouldn’t be loose.
Can you tighten them? is something missing?
Thanks cant tell if anything is missing . I will tighten the 2 bolts and hope this will be OK
Mr Bean
did you get this sorted out?
Tightened it up as suggested and everything went well.
Enjoyed a really good goodwood.
See you all during the year
