Advertised on behalf of a friend…
PG1 Close Ratio gearbox (long 5th) with Quaife Diff & Steel Caged Bearings
DVA ported & polished Head, Verniers, Piper Springs, 285h cams, VVC Blanking Kit, 2 sets uprated headbolts
Vibration free balanced/heavy metalled crank
Scholar EVO 4 Block 80mm bore
JE Pistons - Custom 8.5:1 comp ratio (must be used with 2mm shorter rods) - Ceramic Coated
Carillo Rods (2mm shorter, to be used with above pistons)
GT28RS turbo - ceramic coated
Oil to water cooler & fitting parts
Hybrid FMIC
Siemes 660cc high impedance injectors
Nitrous kit & controller
Raceline Metal Head Gasket (re-useable)
Turbo Manifold, Oil Feed & Returns
Landrover oil rail
Walboro 255lph fuel pump
AEM Adjustable fuel pressure regulator
Custom flywheel for using 228mm turbo clutch
Helix organic clutch plate & cover
6x205/50/16 RB5 semi slicks (4 very slight use)
Contact [email protected] if anything interests you.
