Picked my car up from Plans now with LSD, ARB, RS14s and 46mm Ohlins .
The car looks very purposeful with its lower ride height. While we were waiting for the car to have the final set up finished got to see these been shaken down
Was surprised to here that McLaren owns the facility and Plans along with Top Gear lease from them. The shake down seemed to be brake orientated with a series of stops from road speeds building to a top speed stop. They sound great!
Also saw one of McLaren F1 carbon tubs getting painted.
Unfortunately the track was wet and McLaren had taken a while to shake down and I needed to head back to the burgh. So had time for a quick lap of the TG track that is tighter and turnier than it looks on TV. Will have to wait for a definitive dry track test to really see what the Ohlins do but first impressions are very good. I actually think the road settings are better than the standard suspension. New pads have great inicial bite, big improvement and no ill effects from the LSD So am very happy
Just can�t wait for a track day
The car has yet to see a dry road but the road settings on a wet track were impressive (my wet track settings are a few clicks softer generally including the ARB). The real thing will be a dry track, positively drooling with anticipation! My main concern was what the LSD might do but apart from hooking up and just going no other effects
Sun strip was by way of Mr Pesky, ask nicely and he might still have some
are you planning on altering the arb setting along with the shock absorbers on trackdays?
Really interested in seeming some more pictures of the installation and the adjustment of the Ohlins, together with your impressions after a few more hours on road/track with them.
The pics are of the front driver side looking back. In the first you can see the inside of the wheel on the left of the pic. The first shows the ARB the second shows the Ohlins.
And yes I do intend to change the ARB depending on conditions.
Plans suggested four settings
one for a dry track
one for fast road
one for a wet track
and one for standing water type wet track with the ARB not attached.
Will update as I put some miles on
BTW the LSD is great, I have a tricky road I have to pull out on one the way to work and I used to always end up spinning the inside wheel instead of getting out the way of the on coming bus! Now its great I come out the turning with no wheel spin just a bit of opposite lock
Disconnecting the arb - wouldn’t it flap about a bit - you are relying on it being held only on the bushes?
Remote reservoirs - was fitting them in the front services hatch ruled out for some reason? The adjusts may be different to the Nitron ones (I have no idea?) but I have heard several people comment that that get stuck/seized from being in an exposed position at the top of the damper. Yours look even more exposed.
Not overly keen on the fact that the braided pipe to the reservoir possibly gets to rub on the chassis!
If you disconnect the ARB it only needs doing at one end. The disconnected drop link can then be cable tied out of the way to make space for the ARB to move freely.
