Cool, what spec is that car? I am guessing stock 260?
We do know that it isn’t a 260 spec, but not too sure on the exact spec.
Seans car will be the true test, as that is known to be an unmolested factory 240 PP car, with the addition of the 260 spec fuel pump kit, from Seriously Lotus.
Bear in mind that all dynos give different readings from each other, and cannot give a true comparison without a back to back run, etc, etc, etc, etc!!
Nice work
[quote=JDS]We do know that it isn’t a 260 spec, but not too sure on the exact spec.
Bear in mind that all dynos give different readings from each other, and cannot give a true comparison without a back to back run, etc, etc, etc, etc!! [/quote]
Seans car would be the same as mine then as mine has the same injectors and fuel pump but obviously the 260 ecu, look forward to seeing what you get out of it
I’m interested to see what the results are with mine also, but it must be stated that the object of the exercise isnt to ring out every last BHP from the car. We are simply getting the map done on the Syvecs ECU.
The only reason we made the car ‘260’ spec, was that all it needed for that was the uprated fuel pump, so it seemed like a no brainer.
[quote=SeanB]I’m interested to see what the results are with mine also, but it must be stated that the object of the exercise isnt to ring out every last BHP from the car. We are simply getting the map done on the Syvecs ECU.
The only reason we made the car ‘260’ spec, was that all it needed for that was the uprated fuel pump, so it seemed like a no brainer. [/quote]
As you say it seems like the obvious thing to do, if the map supplied will run a car like mine out of the box then it seems like an easy sell.
If it will plug and play into my car allowing me to sell my ecu on to offset some cost then at the right price I am sure I’ll be looking at it. Can places like TDI north map it?
It should have a better than stock tune out of the box plug and play and then allow tuning for whatever upgrades you add…
Let you know next week
Definatley is infinatly adjustable for all new upgrades that you want to go for.
