Looks stunning John, a real credit to you mate. But if the pleasure has been in completing the project, then get rid and onto the next!!
Been watching in adulation but times move onâŚ
Well done buddy , a top car
Thanks fellas
One question I keep being asked is how much I have spent on the car? I really donât know, I kind of lost track but if you know your applesâŚ
Bonnet hinge and shims anodised
Bonnet latch striker and spring assembly zinc coated
AC removed
Front shear panel anodised
Chassis Aluminium cleaned underside, front & rear
Crash structure cleaned
Horn refurbished
Heater box refurbed, fixings zinc coated, motor refurbished
New custom powder coated aluminium battery mounting with AC cooling bypass and washer bottle mount
New washer bottle and pump EP
New washer nozzles EP and OE caps anodised
New wipe blade EP
New Odyssey battery
New electrical cut out EP with custom mounting
New OE heater hose
Refurb resister assembly
Front hub carriers cleaned and polished, new hub assembly EP, bearings and circlips SL
New tow post assembly EP
New driver spot lights and fixing assembly EP
New silicon radiator hoses/pipes EP
New cooling fans EP and fixings ES
New Pro Alloy triple pass radiator
Full suspension refresh including: Wishbones, ARB, ball joint carriers front & rear, steering arms, rear hubs, lower rear wishbone brackets to chassis, upper damper mounts shot blast, zinc coated, POR 15 clear applied, 2 coats.
New ball joints and bushes SL
New drop links SL
Suspension refresh kit including all shims SL
New Ohlin 36mm 2 way dampers 325/450
New ARB mounts EP
New rear tow links and shields EP
Steering rack serviced at Titan including new gaiters
New track rod ends SL
Front latch mechanism shot blast, zinc coated and mounting power coated
New OE brake dust shields
New brake master cylinder SL
New clutch master cylinder SL
New OE rubber connecting hose
New braided hoses front & rear SL
New AP front brake discs and bells SL
New EP rear discs with refurbed bells (anodised)
New rear brake lines
New OE front and rear brake callipers
New Pagid pads front and rear SL
Dot 4 brake fluid
New OE handbrake secondary
Passenger bulkhead stripped and cleaned
Stays stripped and painted with POR 15 black. Caps added.
Rear subframe removed, stripped and galvanised
Spacers to chassis shot blast, zinc coated and POR 15 Silver applied
New OE longerons
Fuel tank removed and replaced with new larger Pro Alloy tank
New fuel pump SL
New silicon fuel tank filler and breather hose
Fuel filler assembly shot blast, zinc coated and POR 15 clear applied
New fuel filter and HPE mounting
New braided fuel hose, unions and rail fixing
New filler assembly stainless ring and gasket
Aluminium shear panel stripped and anodised
Aluminium cooling pipes polished, mounts zinc coated
PRT kit/grey EP
New header tank EP
New silicon cooling pipe/hose EP
MAP/BARO vacuum mount shot blast, zinc coated and power coated
Solenoid valves vacuum refurbed, new silicon hose
New vehicle speed sensor EP
New OE throttle position sensor
New aluminium mounts to hub
Engine gearbox mounts shot blast, zinc coated and powder coated
Door spring plates and hinge shims shot blast, zinc coated and powder coated
Alternator mount shot blast and zinc coated
Alloys shot blast and powder coated
New Yokoham AD08âs
New aluminium wheel bolts HPE
New aluminium boot floor
New OE heatshield boot floor
New OE heatshield above cat
New aluminium undertray and OE NACA ducts
New aluminium diffuser
New OE throttle pedal assembly
Brake & clutch pedal anodised
New aluminium engine divider
All interior removed, inside clean throughout
Footwell vents blocked with anodised aluminium panels
New FEV gas electrically operated extinguisher 2 nozzles inside cab and two in the engine bay
Seat mounts stripped, shot blast and powder coated. Driver rails cleaned regreased and wet sprayed
Interior trimmed at Allon Whites include:
Seats, upper dash panels, dash cowling, door trim including handle pull trim, sill trim pads, roof lining and steering wheel including new horn and badge. New quick release plastic fasteners.
Carpet under seats
Bulkhead trim cleaned
Stereo and speakers removed, anodised aluminium blanking plates fitted
OE Dash stereo blanking cover fitted
New adonised aluminium floors panel bonded over old with Sikafkex
New OE mats
Foot rest, window winders, foot divider and foot rest stripped and anodised
New OE rear tunnel cover
Body painted gear lever and hand brake covers
New OE hand brake handle
New OE gear knob and shrink sleeve
New OE cigarette lighter and assembly
Painted dash, dash inserts including trinket trays and steering column shroud
AC & Recirc switches replaced with OE switch blanks
4 point harness washed and cleaned, one new buckle fitted
New windscreen and rubber bead
Windscreen surround painted
Door striker pin shot blast and zinc coated and new OE plastic surround
Interior roof mounts stripped and POR15 black applied
Refurbed gearbox. HPE
New OE wheel arch liners SJS and weather strip
Head light bracket shot blast and zinc coated
New headlights and seals EP
Front and rear grills powder coated â front clam inc side and rear clam fog/reverse
Airbox back plate shot blast and powder coated
Ceramic coated manifold, flexy and decat.
Exhaust stripped, cleaned, repacked and wet sprayed with high temp paint
New V band, blue mounts and refurbished fixing shot blast and zinc coated
Full VHPD engine strip & rebuild
Reface valve seats
Hone con rod small ends
Soda Blasting
Silver high temp engine paint
Mahle motorsport Main bearings
Mahle motorsport big-end bearings
Thrust washers
Westwood ductile Liner Set
(OE) Sump baffled
Uprated main bearing ladder
Forged Wiseco Piston Set
ARP con rod bolt set
Throttle body/ injector clean & service
Gasket set (conversion kit)
Gasket set (head set)
Oil pump
Water pump
Head bolt set
Timing belt
Timing belt manual tensioner
Alternator
Starter motor
Kent Cams vernier cam pulley set
Kent Cams VS51 valve spring set
REC757 S/S Inlet valve VVC 31.5mm Paul Ivey
REC758 S/S Exhaust valve VVC 27.3mm Paul Ivey
New OE oil cooler, new unions and braided hose
AP clutch kit
New clutch slave with strengthen kit EP
New clutch arm with reinforce wielding EP
New engine steady arm, both parts EP
New OE hydromount assembly
Refurbished upper engine to chassis mount, shot blast, zinc coated and powder coated
New OE breather rail and silicon piping
New OE driveshafts
Xylan Coated rocker cover
New alternator cooling hose
New Nimbus single skin manifold/bulkhead heatshield
Refurbished OE bulkhead heatshield covered with Agriemach aluminised heat barrier
Airbox cleaned inside and out
New OE hose intake duct to airbox
Refurbished OE air filters (aka witches hat)
Refurbished and clean door seals with 3M VHB tape applied
Door hinges cleaned, new caps
New outer window seals ES
New OE door access caps above latch
Refurbished cleaned inner seals
New OE Meta immobilizer
Refurbished OE Meta keys
New OE front clam harness
New OE engine harness
New JSR rear clam harness
Main harness (most) sleeving replaced for new, front, rear and inside
New OE indicator/flash arm steering column
Refurbished headlight lens covers
All bodywork painted original Chrome Orange paint code B25
Roof, engine cover and bonnet grills POR 15 black applied
Roof/engine cover hinge painted
New OE Lotus nose badge
New OE indicator lenses
New OE side indicator/repeaters
New OE Lotus & Exige decals
Refurbished front number plate mount, shot blast & powder coated
New OE labelling fuel, jacking, films etc.
New OE rear clam brake, indictor, EP fog, reverse light and number plate light
Refurbished reflectors
New OE engine cover latch mechanism and cover
Refurbished striker shot blast and zinc coated
New OE stone chip protection rear clam (black)
New rear clam rubber strip to sill
New OE vehicle manual & service book
Good grief.
ÂŁ5?
Lol a fiver
I counted 2 x washer bottles and pumps.
AC removal these days is a NCO.
Refurbished horn. Ooo er Mrs. I bet you polish it every time you visit the garage.
Please donât go ahead with the final (unlisted) itemâŚnew owner
Funny I knew someone would notice the washer bottle, I deleted it over on MLOC you tosser
takes one to know one
Longest single post awardâŚâŚâŚ
Finished!
Well I say finished but it needs a clean so some detailing and a ceramic coating early may
Lovely mate, the ceramic coating will really finish it offâŚ
Thanks for the contact Rob.
Looks absolutely fantastic.
Amazing! And itâs not coming to Anglesey. Shame
That looks stunning Jonny amazing work
Congratulations Jonny, your Exige looks fantastic . Any plans for a new project?
Cheers guys.
As good as yours hopefully Klaus A barn find 912 would be nice
Your Exige is in a totally different league than mine, Jonny. I just put mine back on the road where as you performed a full nut and bolt restoration.
My car still shows lots of signs of usage and actually would benefit from a paint job. But the way it is Iâm able to use it more freely without caring too much.
You need a new project for sure. I hope youâll find a demanding new one.
