reset your throttle pot calibration.
Hey good to hear from you Phil!
First post this year! Hope you and family are well.
Gonna make Croft (28th April with 20+ other Exiges, see trackday section)?
Hi Phil
I second all that Ian says
Hiya Phil!
Done that about 30 times already, every time I adjusted the throttle screw I reset it just to be sure…
But I didn’t want to set the fuel cutoff to much higher than the base TPS signal or it judders when on v light cruise as it keeps cutting off fuel…
And even then it should never affect idle (but always seems to) as it shouldn’t be engaged until it’s above 2000rpm scratches chin
I think my Emerald has gone all stupid! I can’t download maps with the engine running anymore either
I told you… Titans are made to have an IACV.
Put it back!
Reading the above concerning the judder,mine does that as well, it is going in on Tuesday to remap the ecu as it runs far to rich at idle and is a pig on constant light throttle.
Perhaps the IACV is not to blame for this as mine is still in place and it has the same symptoms, although i cannot confirm any of the settings of ecu but will be able to shed some more light on tuesday, i have no inclination to try and set it myself, spring rates and damping keep me busy enough . What does the service manual say you have to doaside from the plumbing when you remove the IACV, there is a section on it in the motorsport or 340R section,will have a read quickly.
Not very much info, they just say not reccomended for road use and that idle speed should be checked to avoid excessive emissions, but i am sure emmissions are the least of your concerns right now.
I have to agree with Uldis and reccomend replacing the unit for road use, the 340r section states that it saves 667g, i think they were clutching at straws for weight saving. When i asked my race mechanic if i should take it off he said that i would really only create idle problems and not benefit much. The only thing i could think would have to be changed is the screw on the throttle bodies for idle, any other changes are going to create problems elsewhere in the map.
Not worth getting new TB’s just to get it to idle, but that might be necessary, as one idle screw cannot adjust itself to all sorts of conditions as the ECU can with the IACV, especially when t they were desgned to use it.
Heh heh, no it’s fine, it’s my spastic ECU!
The fuel cut-off I’ve never been able to get right even with the IACV, it should have nothing to do with it… In fact 100% has nothing to do with it
So it’s just the fuel cutoff getting over active… Bastid thing
First post this year…ohhhh that’s scary Ian
We are all well thanks, just coming out of the Winter hibination mode, lots to do, lots to plan, engine to rebuild (still!!) so wont be coming to Croft or doing much socialising
oi Phil, great to hear from you.
glad that everything is ok with you. Indeed, you have been really quiet. A lot is gona change here as well. In October, we will be three of us
I know, I have a lot of catching up to do
take care and another massive shout goes out to Trudy.
laters,
Bruno
PS: don’t know yet what is gona happen to the Exige
Hey Bruno, CONGRATULATIONS!
ps. NOTHING should happen to the Exige! It’s important for new dads to have an ‘escape’.
But will he let the milkman drive it?
Seriously though, that’s fantastic news Bruno & Renate
By the way Bruno, Mrs Pesky, Pesky Minor & me will be in Les Carroz (near Chamonix)during the first week of August. Any chance we could meet up there, or is it a million miles from your place?
cheers, mates, nice one
Ian, I think you have got a point there
Rob, great news but why do you spend yer money with the french frogs instead of Switzerland
We have to sort something out me thinking at least it’s closer than me driving to the island
(5 hours drive) Do you come by car?
laters,
Bruno
Bruno
I’ll email you
Bruno
Congratulations to you and Renate… its not got any Scottish blood in it has it … all the very best.
cheers, Rox, but I’m not gona tell ya
laters,
Bruno
Congrats!!
cheers mate
laters,
Bruno
