is the standard exhaust stainless?
On a steep learning curve here so bare with me…
But my allegedly standard exige s sounds louder than the one i tried before with a stage 1 exhaust at the dealers, imho. I’ve removed the diffuser to have a look and other than to confirm its a single tip stainless backbox i can’t do much else. Is the standard one stainless and if so is there any identifying marks/codes on it that i can check? This one actually sounds quite load and boomy/droney above 3k with WOT which i can’t remember the stage 1 doing. Thanks for any help, sc.
That does not sound like a standard exhaust, AFAIK they were never stainless either, my standard S sound like a sewing machine till it got 2bular’d :wink:
Agreed very quiet as standard.
mmm, might be just as well to take it off to have a more detailed look!
If it is really heavy it maybe the Lotus Stage 2 or 3, if it is not really heavy it is an after market system.
If the backbox is small it is aftermarket.
Here are pics of my ex Larini (loud) and my current 2bular…
hmm the plot thickens, heres a pic of a standard one i found;
and heres a couple of my one;
definately not the same, different exit from box, different fixing for tailpipe.
size is approx 18" x 8" diameter.
2bular…bit of luck there matey
cheers, must be going soft as its a bit too loud for me and thats after coming from a 360 with a TUBI style fitted which could actually set car alarms off :slight_smile:
Actually not sure now I look again…I don’t remember a bracket between exit and silencer.
That looks like mine and i was told my is a stage 3 made by forge, i will check later .
Mike
Yes just looked and from what i can see its the same, my diffuser is still on though.
Found this, Click Here
In steps the exhaust man :smiley:
That I am almost sure is a Janspeed stage 3 by lotus, you can tell by the welds and the position of them on the exit pipe.
The Forge is similar but has a continuous sweeping bend rather than two 90’s on the exit pipe.
It should be stamped janspeed on the back box.
Boothy
Well spotted.
I,ll get my coat :blush:
Mine,s a Janspeed stage 3 on a 2006 “S”.
I now think it sounds great after initially thinking it was a tad loud.
It can be heard on “u tube” if you wish…
- YouTube
cheers JK
Mine is lotus Stage 3 and looks just like that. Is loud aswell IMO so maybe thats what it is. Does it pop and bang quite often?
just confirmed by previous owner - stage 3 lotus from new!
“Sorry thought you knew that” :slight_smile:
and yep, pops and bangs a fair bit too.
