Interior carpet and ali trims
Going to add the vertical carpet and ali trim to the Exige (those along side the driver and passenger sides of the chassis) and just wondered if anyone could recommend a product to stick the ali strips in place on the chassis? Ordinarily they would be riveted on, but I’m guessing that is not a sensible post-factory way of attaching them?
just use double sided tape? should stick well and easy to remove later :wink:
Have you got the carpet?
I think i have some here of not.
I’ll send you some 3M metal to metal tape if needs be, sticks like shit on a blanket. Use it at work.
[quote=TarmacTerrorist]Have you got the carpet?
Yep got both the carpet and trims, but thanks :slight_smile:
I was hoping there would be something like that out there, that would be great. I’ll PM you :slight_smile:
No problem Pete.
It certainly does mate! :open_mouth:
Took a while to get round to it, but the strips are now stuck on, and we have plenty of the tape left if you want it back?
You’ll find another use for it :slight_smile:
