I have the harnessbar that is part of the Exige Cup rollcage.
Fitting a cam is easy. All you need are a couple of bits of metal for a couplke of quid and a miniballhead camera mount. Depending on how you mount the ballhead, you can get almost any videocam in � and I would agree, DV is vibration proof compared to a DVD version.
Here is my current simple setup:
An axle clamp of appropriate size from a DIY store:
[image]http://www.imagestation.com/picture/sraid225/pb46e54cbb31f2730e3bb8980cfabcc8c/e9b3d3a7.jpg[/image]
Used with a straight section of metal bolted toigether around the harnessbar and a L-angle bracket to mount a Manfrotto Miniballhead. Side view:
[image]http://www.imagestation.com/picture/sraid225/p953921e8a1e785f492c3095114eaa3ff/e9b3d388.jpg[/image]
Front view:
[image]http://www.imagestation.com/picture/sraid225/p733b781ffb2722fdd0af107dd87b6839/e9b3d37d.jpg[/image]
I’m currently using my 4th Sony miniDVcam. This one is only 880,000 pixels, but easily adequate:
[image]http://www.imagestation.com/picture/sraid225/p51e0e9bbec5241bca1179d45167e2268/e9b3d369.jpg[/image]
Any clips are fine on a Mac/PC/TV � and on Google or YouTube they are hugely compressed anyway.
FWIW, here’s a clip from that cam*:
>clicky<
Here you can directly compare an old (2000) Sony minDV with 880,00 (rear-facing) with a Sony PC-101 (megapixel chip) (the frontfacing cam):
clicky<
I’ve even used a very large, 3-chip Sony miniDV � also from about 2001/02. But, again, the compression for the website is the biggest factor:
>clicky<
One thing I would watch for when choosing a cam is that it has a record button on the fold-out LCD � if you want to conserve batteries by switching it on and off when required, it is far easier with this facility when you’re strapped in with 4-points.
*P.S. Caymans are not that fast!
