Impact Wrench
So I bought an impact wrench and some sockets to go with them but I just wanted to check whether anyone else is using an impact wrench with the spinned wheel nuts on the exige?..yours…without mechanical sympathy
Jimbers
I have a battery operated one from when i used to take spare wheels to trackdays, you will find that it will not loosen off tight wheel nuts, i would not use it for the final tightening of the wheel nuts either
its usually the air operated ones where you can set the torque level that do the damage liek the kwik fit boys who set them at max so they can use them for taking off and tightning wheel nuts
Phil…thx for that…I’d worked it out BUT for a mechanical numpty like me its the re-assurance that counts…like, WHEN do you use a washer? Do you grease bolts/screws? What do I do with all the bits I always seem to save whem I put something back togehter?
Those kind of questions really freak me out!
Thx for the reply?
