had the immobiliser woes managed to cure by bypassing the bloody thing SGT threw me a bum steer by saying that the immobiliser stops the fuel pump from priming so i was looking elsewhere then decided to bypass it anyway just to confirm and off she went why is this immobiliser causing so much hastle does anybody know what goes wrong with them and can they be fixed? can anyone tell me where i can get the bypass plug from save me making one SGT have stopped selling spares
All without stopping for breath too
Breath? Just look at the poster’s name
Whenyouareasquickasyouarematewhoneedstostoptobreathavagagoodweegendmate!!
My immobiliser died the day before the Hethel 60th. Took me a couple of hours to work it out, but you only need to push bridging wires into the connector in the correct places and then tape over them to stop them moving - no need to buy a bridging plug.
Where is the immobiliser located? Somebody told me you have to remove the whole front end to get at it. The car won’t start. it cranks but no fire. Thanks.
Jim
The car is a 2006 Exige with Toyota engine. I would like to drive the car to the dealer rather than have to have it towed 50 miles. It is under warrantee. Thanks.
Jim
If it’s under warranty get them to pick it up?
Jim
Have you tried changing the key fob battery?
I did not try replacing the fob battery as it works the door unlocking mechanism. I tried both keys with the same results. All that happens is the engine cranks but won’t fire.
Jim
Jim
Bugger - just thought there may be a quick answer for you.
Good luck - probably summat & nowt, but needs the dealer to fix.
