This post isn’t me having a go at anyone, just trying to offer some help and maybe a word of warning.
As regualar readers will know I currently have an oil temp issue when on track and I am in the middle of fixing a fuel pressue issue.
How do I know about these problems??? Because I measure various temps and pressures, so that I can fix any problems before they cause something to break. So I guess I am aiming this at those of you without any auxillary gauges.
The thing that worries me guys, is that I have the same car as the rest of you, so if I am having the problems, then its a good bet that you are to. Even you guys with honda and audi conversions are not going to be immune to these little issues.
Please do not think I am scare mongering here, I just care about my fellow enthusiasts and don’t want to see anyone with a big bill and the associated stress and hassle that mechanicl problems can cause.
A drop in fuel pressure will cause your engine to run lean and over time, it will melt (tThis time can be measured in seconds in extreme cases).
A drop in oil pressure, even for only a few seconds can kill an engine. I know I have done it. Long fast corners and sticky tyres connected to a well handleing car can throw all of the oil to one side of the sump and your oil pump sucks fresh air, and hey presto you’ve spun a bearing.
Oil temp is also important, oil as we know has an effective operating temp range. Just like thrashing your car when cold, giving it stick when the oil reperesents knats piss (because its so hot) is just as, if not more harmful.
I know gauges aren’t cheap especially if your not fitting them yourselves, so I have been trying to think how to help out.
I reckon I could bring some testing gear to croft, that would test fuel pressure. I could rig up an auxilary gauge to a bit of pipe with the right connectors so it could be fitted in 5 minutes just after the fuel filter. The gauge could be hand held in the car and the fuel pressure monitored on your next outing on track.
For oil temp, I am sure I could rig up a dip stick type temp probe (similiar to that used on some MOT tests) so that people could dip there oil and see what the temp is when they come off track.
Oil pressure is more tricky, as the pressure sender isn’t just a quick in and out thing to fit. Hmmmmmmmmmm, i’ll have a think about that one. Anyone else got any ideas???
I reckon though that one of the SPA dual oil temp / pressure gauges should be on everyones Christmas list.
Better to be safe than sorry I guess.
Sean…
