Having looked at the RLS option of getting side air into the intercooler I set about designing my own.
Key points for me were:
1)Leave L/H scoop alone so as not to interfere with intake…
2)Increase ducting diameter over RLS to compensate for using one side…(RLS use 2.5 inch)
3)Not obstruct anything so as not to make access to service parts awkward…Ohlins resevoir etc…
4)Reasonable cost…
Scoops just bonded in place with RTV sealant …
Aluminum couplings bonded in using epoxy then RTV to strengthen…spread stresses.
All the bits aluminum and duct etc are from Demon Tweeks in the UK …
They do mail order …
Good job John, looks good. Have you noticed any difference in driving, i.e. have you let the car get really hot an then noticed it cooling quicker with less soak?
To be honest Mark , ever since I ditched the standard IC I’ve never noticed any heatsoak…I don’t commute and sit in traffic… and when I go for a drive its on open roads .
I’m just building in ‘headroom’ for the next steps … and I really enjoy improving the car while I’m short on work …
Looking at the aperture that the roof scoop squeezes air through , I would say that now it probably flows around 300% of standard …DISCLAIMER…I,m estimating !
I’m taxing it in the next few days and will be at Anglesea.
Hope you can make it .
Jfk… curious about the roof scoop mod. would the air not be forced in slower? just thinking about a hose pipe, smaller aperture forces the water out faster/further. i’m no expert on IC’s so have no idea if they like controlled air literally shoved in, or prefer air in abundance??? I’m still learning so your view appreciated.thanks
it’s VOLUME of air passing through the IC fins that cools the intake air … Bigger roof scoop + additional ducts all increase the volume passing over the fins…
[spoiler][/spoiler][quote=speedfreak]gotcha…do you have a forge? silverstone Lotus said that Lotus do an upgraded performance IC? [/quote]
Here you go …
