Dose the Exige have a problem with oil seals, Its just that when I did an oil change about a month ago there was a bit of oil on the under tray and it looked like it was emanating from the bell housing. Now its pi55ing out of the under tray area!
I checked with B&C today and my warranty ran out on the 21st of this month�Bugger. Better crack out the spanners then! What I need to find out now is how can I prevent this happening again? Because at this rate it�s almost change a main engine oil seal every oil change!!! Plus are there better quality oil seals available from anywhere else?
I had my last one “sikkaflexed” in. I have heard of someone who had theirs threaded & screwed in. Also, have you got the breather kit? Check the cam cover for blockages to the breather outlet.
Russ T, what is �sikkaflex� is it a type of silicone sealant? No I don�t have a breather kit where could I get one? I still can�t believe this has happened, roll on the day when I can get my hands on a nice VTEC! Oh yes�
I think it is the industry standard sealant.The breather kit is available from Lotus, though I would imagine it is not too big a job to get one made up…
