because of having bad idle at cold start the last few days (and therefore starting to develop bad temper), i wanna try and clean iacv and wheelspeedsensor as this might be the cause
any ideas what will be the best way of removing iacv:
from underside after removing undertray
from top after removing airbox assembly
Check all the vacuum pipes for leaks before you attack the rest…had the same prob found it to be split vac pipes on the inlet manifold.
Hope this helps
