Hi
My battery is complete empty. There is no sign from the car when using the remote controled key fobs. When I try the key nothing happens.
How do I get in?
Q.
Hi
How do I get in?
Q.
Take the nearside inspection hatch off the front clam and there is a jumper post in there to attach jump leads to if you’ve got a S2 which I assume you have given the section
Yep, I have a S2.
Thanks I will use them next time (opening the easy way ). I now have used a piece of TIG wire to get in (the lock knobs have a nice grove that holds when I pull up the wire). Together with the key I managed to open the car.
Q…
Glad you got it sorted
COuld have used the ‘automatic centre punch method’ on the driver’s window as used by someone on my car the other night at 2am…
barstewards…
