Help me, please!? :- (
Someone has a diagram and photos harness to fit K-Pro ECU Honda K20 engine with JRSC on Lotus Exige S1?
Tell also [email protected]
Many thanks
Are you looking for details from the Lotus service manual or from the actual conversion side?
Thanks Andrew
"Fanta"stic ))
No worries and now I understand “Fanta” man !
Hahahahahaha
Hi, I have the cables mounted but the fuel pump will not start.
Who can help me?
You have wired the pump through the relay so that the Honda E1 connector earths the relay coil ?
On the standard Exige wiring the ECU gives out a 12v signal …
Thanks Andy
you wrote this in your helpful notes
But my old age makes me silly… Hi hi hi
[quote=AndyD]You have wired the pump through the relay so that the Honda E1 connector earths the relay coil ?
On the standard Exige wiring the ECU gives out a 12v signal … [/quote]
Many thanks Andrew
This film for you
Guys can I ask what you did with pin E8 (O2 relay GND)? Seems the O2 sensor turns on with the main relay, so did you feed a dummy 12v to E8? If so what did you take it from?
T
[quote=Fantaman]This film for you
ILLA ed ILLO risorgono ! Orangeman è tornato... on Vimeo [/quote]
worst case of overspray I’ve ever seen!
