Is this a joke??? Where is this from …who does it belong too??? who made this conversion???.. drag car only??? what??? how much is it??? when can I buy it??? how is it on track??? to good to be true
Maidstones offical numbers are here SELOC Forums Apparently the S/C numbers are out of date and have moved onwards and upwards. Note: These are from a Dynopac so read the post to get an idea of an Emerald equivalent.
I’d be interested to see the results of one that’s been dyno’d recently.
I’d better present the big picture here and include the rest of the information from Seloc.
Maidstone used Abbey Motorsport to develop the maps for the conversion. Abbey uses a Dynapac dyno, this is unique in that it bolts onto the hubs and removes a big variable i.e. the tyres from the equation. Tests on the same engine done at Emerald and Abbey showed a 15% difference between Emerald’s simulated flywheel figure and the Dynapac hub figure.
Since Emerald seems to be the default standard the actual figures would be:
279.45hp and 195.5ftlb, as I mentioned things have moved along since then and that figure is now a good chunk higher…
