Maybe it’s me being paranoid but my gearbox sounds like its got louder.
I assumed it was a clutch release bearing until I jammed my brain into first gear, and its noisy with the clutch up, winding down as I dip it, so finger points to input shaft bearing?
I get a slight whine in 4th, but it shifts sweetly enough and stays in gear fine. Am I being paranoid or is it a known thing?
broke my 4th gear at my victory at Lotuscupeurope at redBull circuit. No noise before - just one big bang and all the teeth were gone
Luckily it was 3 laps to the checkered flag and my 6th gear lasted till the end.
Bad Luck when its a JDM gearbox - then its expensive
Paltry 1.2-3 L came out of it, rest seems to be on the casing and rear tray. Seems the input shaft seal is lunched. Thought I’d fill it anyway so I can get it to track club for a proper look over, swallowed 2L of fluid and even then didn’t dribble out of the filler hole.
Suppose question now is if I get the clutch done while the box is out. Hmm.
Well 2.1-2L of Motul Gear 300 and it’s not grumbly, still can hear it’s in motion but sounds much happier.
Downside, I only fetched 1.3L out of the catch tray/bottle. Obviously there was still probably a healthy coating in the catch tray there is no doubt it was down on fluid. Scuffers suggested to check the shaft seals, clean n dry. I’ll just have to keep an eye on it.
