Honda S1 shift lights
Any of you Honda Chaps running shift lights ?
If yes, which type and where have you fitted them ?
Thanks
Ex77
I know Deano over here used the Ecliptech shift-i to good effect on his Elise. Think he mounted his atop the binnacle:
<LINK_TEXT text=“http://www.performancecar.co.nz/article … elise-s1-4”>http://www.performancecar.co.nz/articles/honda/hybrid-theory-2013-1997-lotus-elise-s1-117/attachment/pc-117-hybrid-theory-lotus-elise-s1-4</LINK_TEXT>
I run a MoTeC SLM, which is no good unless you’re running a MoTeC ECU, but I much prefer mine mounted thusly, underneath the instrument cowl as it’s not obscured by the steering wheel and it doesn’t get in the way of the tell-tale lights like it does if you put atop the steering column cowl.
[video:youtube]SEXIGE at Hampton Downs - 01-09-2012 - Run 2 - YouTube[/video]
Ecliptech shift-i
Superb bit of kit - highly recommended.
I have OMEX fitted in the same place but would probably give those a go if starting again.
Ian :slight_smile:
Ian :slight_smile:
[quote=Mr Pesky]Ecliptech shift-i
Superb bit of kit - highly recommended. [/quote]
Does she light up all yours then mate! :smiley:
Ordered, Thanks.
Where have you mounted them ?
Any pics ?
Ex77
Henry
Using velcro…
Pesky, how do you get on seeing it there? I tested my MoTeC one there and it was obscured by the steering wheel. Perhaps it’s just in the way I sit or my size. Hence why I slung it under the binnacle canopy.
Ha!!!
As you say George, you have never met anyone here!!!
If you met Rob, you would know WHY!!! :smiley:
:smiley: :smiley: :smiley:
Rob is a pixie and has to sit on a cushion.
I heard it was that Rob’s new GF was a pixie and actually sits on his cushion!!! :smiley:
Lol… don’t worry, I still love you guys :slight_smile: Even though I wouldn’t know you if I passed you in the street (not likely unless you come to NZ for a visit!)… although I’m thinking of coming over to the Goodwood Revival next year :slight_smile:
Back on Topic, I thought these would be an easy instal but I am told you can’t take the feed from the tacho as the signal isn’t strong enough and you have to take a feed from the ECU.
Anyone had a similar problem ?
Thanks
Ex77
Nah, shouldn’t be a problem - feed is fine from tacho on S1
