I have recently converted my S1 Elise with the Link-Up Honda conversion.
I put the car on the cornerweight scales both before and after.
Here are the results.
Weights Pre-Honda (kg)
LF - 133.0
LR - 220.5
RF - 149.5
RR - 216.0
Rear - 436.5 (61%)
Left - 353.5 (49%)
Total - 719.0
Weights Post-Honda (kg)
LF - 134.0
LR - 227.5
RF - 151.0
RR - 222.5
Rear - 450.0 (61%)
Left - 361.5 (49%)
Total - 735.0
These were both done with a drained tank and no roof, on the same Longacre scales on a level floor. The only other difference was changing from the Janspeed Supersport exhaust to the Eliseparts 6" version. The Eliseparts exhaust is 1.2 kg heavier than the Janspeed due to it being somewhat larger. I weighed them both.
Nothing > else was changed during the conversion and nothing else removed or added so this is a true representation of the weight difference the Honda conversion makes.
HTH
Dan@JPS
Huuuuuuumn, doesn’t add up, - that’s not to say I think you are lieing - the standard accusation from dva, and Dave oz when someone disagrees with them, but the sums just don’t tally.
I havn’t got a honda to weigh, but scuffham himself gave it several times on seloc as 172kg, now I don’t know exactly what that represents, but always guessed, engine, box, alternator, starter, exhaust.???
A base std K weighs 96kg with 5kg manifold, loom, alternator, starter, and a box adds 37.4kg to that plus 3.8 for the starter. If we subtract 5kg for the manifold and add 20kg for a complete exhaust, we have
96 -5 = 91 +37.4 +20 + 3.8 = 152.2kg against honda wt of 172kg
so conversion addition 20kg
so the figures don’t add up??? but rather than call anyone dishonest, the only way to settle this is to get a honda and compare engines on the scales. Have to start looking for a bust one…
However you completely miss the point roadboy, because yes you have a honda, and 200/220bhp and have gained 15 or 20kg of weight over someone who has a K and 9 or 11 grand in their pocket to spend on their K.
With much less expenditure than that you not only end up with a much lighter K to widen that 15/20kg gap, you end up with more horses, more torque,and a much much nicer engine to drive, if it’s been done properly of course.
Photos of std K , tuned K, honda k20 on accurate, calibrated weight scales [not corner weight scales] to follow.
simon
So, we are saying that Dan has measured 719kg pre conversion and 735kg post conversion, therefore a gain of 16kg. However, using 3rd party derived figures there is a 19.8kg figure in mind. Therefore am I correct in thinking we are only talking about a dispute of 3.8kg between derived and measured figures?
If so, I can’t believe there can be cause for too much grief over this element of the debate. In my opinion there wouldn’t be any question of anyone lying as the exact contents of the measured engine/transmission weights, plus differences in weight of other kit elements (e.g. engine mounts, pipe runs, ECU weights, removal of carbon canister + plumbing plus kit options chosen etc) and the weighing procedure can all contribute significantly to ‘error’.
On the data supplied and as an unbiased observer, I’d be quite happy to split the difference and say an N/A Honda adds around 18kg and put that particular debate to bed unless someone else repeats the test.
