HID Light upgrade Help with alighnment
Just finished fitted a set of HID to the car, bit of a job as the kit need modifing but the lights are great, couple of usefull things I though I’d share.
  1. Screw a small self tapper into the plastic clip that holds on the inner wing and them just pull them out, they are not screws really;- if you leave the screws in its much easier to get at the bulbs when you need to change any as you.
  2. When fitting these take out the entire inner wing it give mucm more room to work
Mines an 09 S2 and so fitting the H 7 bulbs means making a small hole in the rubber cap and pushing the connector through, FYI The plug is wired (looking at the bit attached to the car) Top left Common Neg, Bottom Right Dipped beam, Bottom right is main beam, Top right side lights I taped the existing H7 connector to the inside of the housing �just in case�
Just need to check the set up does anybody know what the 0% lines are on the MOT test, Presume the centre in the middle of the car is the horizontal 0% Light centre??
