Hi All
Hi I’ve recently purchased a S1 exige just imported back to the country from France
Hoping to join into a track day next year
As my local is Anglesey Circuit
So here to say hi
Breif spec
---- Interior
Dash2 pro
Carbon fibre speedo cover
Carbon fibre door panels
Carbon fibre door handle trim
Black leather sill protector
Sphere gear knob
Lotus 4 point harness
Lotus Motorsport seat
Oreca steering wheel
Removable steering wheel kit
----- Exterior
Lazer blue
Wiper blade
Carbon side scoop
Door seals
Motorsport fuel filler
Stainless filler surround
Headlamp foam seal
Headlight cover
Smoked indicator lense
Motorsport rear diffuser
Motorsport rear spoiler
Custom wing mounts
----- Breaking system
Komotec brake system (4 and 2 piston alloy brake calipers with 313 mm diameter brake discs and handbrake cable)
Stainless Steel brake hoses
Big bore master cylinder
PFC brake pads
Custom brake duct kit
----- Engine and gearbox
Honda K20 Rotrex Supercharged
Custom Honda 6 speed from rsx type-s with Torsen limited-slip differential
Omex 710 series pro ecu
Battery ballistic evo3 lithium
Motorsport aluminium radiator
Battery isolator switch
Magnetic drain plug
Lightweight fuel tank 48 litre capacity
Clutch AP
NGK sparks plugs
RC Engineering 750cc fuel injectors
Rotrex C30-94 Supercharged
Motorsport quick-shifter
----- Suspension
Wishbone reinforced full set
Front and rear towing
Lotus quickrack
Nitron wishbone bearings
Front toe link ball joint steel
Rear uniball toe link kit
Nitron 1 way 46mm race
Core blimey mister! Nice car! Heck of a spec as well.
The exiges trackday is at Anglesey next year : Exiges.com - Exiges.com - Lotus exige club
Well done, welcome along.
Phew! What a car
Wow, that is an absolute beauty! And a beast :smiley:
If Anglesey is your local track then you can’t be too far from me! :slight_smile:
Hi thanks for the welcome, got a few things to sort out over the winter tho
Refurbish wheels
Re paint rear clam
New clutch
Upgrade dash again
Fresh tyres
Ad roof scoop and paint
And general tidy up
s-express im near Caernarfon haven’t seen you about tho
Welcome! Wow, what a spec, what a car!!
Cor, you’re car has suddenly sparked an interest on here. let’s keep it up.we need to see it in action and get the full story of its return form France
